TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Coolant doesn't run back to radiator?
Mika
on July 17, 2020 at 8:45 AM
posted by mrchips
on July 14, 2020 at 04:14 AM
Brand new and "bling-bling" shiny OEM cap was bad, older OEM cap works like a charm. >> Problem solved, thank you all.
Mika
02:18:29 07/11/20
Mika
02:37:33 07/11/20
The system needs to be completely sealed as cool down >>
ZUL8TR
04:19:23 07/11/20
I suspect you just didn't add enough coolant to the
Polishzx
05:05:33 07/11/20
Re: I suspect you just didn't add enough coolant to the
Mika
22:17:19 07/11/20
Over flow hose
scorp997
18:51:21 07/13/20
I am trying to sort out exactly the same issue.
megaDan
09:33:41 07/12/20
mrchips
04:14:50 07/14/20
Re: Re: Coolant doesn't run back to radiator? -
Mika
08:45:22 07/17/20
What is the pressure rating on the new cap vs the old? (n/m)
ZUL8TR
04:20:00 07/19/20
Re: What is the pressure rating on the new cap vs the old?
Mika
00:12:29 07/21/20
